• Battery Drain issue with Garmin Vivoactive 3 - 7.20 version
    With the 7.20 update i am facing the battery drain issue. Battery lasts for only 1.5 days
  • RE: Updated to v15.33 but had terrible battery drain
    Hello. I am sorry to hear you were having trouble with battery drain. If you are still using 15.33 and are still having trouble with battery drain, I would first recommend trying these steps:
    Why is My fēnix 8 Series Watch Battery Draining Quickly?
    If…
  • Garmin vivo4 battery suddenly draining
    My garmin vivo 4 battery is suddenly draining from 100% to 70% in one hour while I was resting. Normally my battery lasts 3+ days while doing activities
  • Rapid battery drain after activity on Venu 2
    Since updating my Venu 2 to the latest software (8.11), my Venu 2 now drains rapidly after an activity (with music and GPS) has been stopped. This battery drain will typically be about 6% per hour, whereas I will typically lose 10-11% per day without…
  • Battery drain with latest version 3.22.1.5
    Is anyone else seeing insane battery drain with the latest version of the app? I have been riding all summer with my Edge 820 connected with livetrack and normally see about 30% use for a 4 hour ride. Since this last version I am seeing 30% in 1.5 hours…
  • Bug? Abnormal battery drain after using timer
    I want to report that everytime I use the timer (i.e for cooking pasta Smile) the battery got drained much faster then normal, until I do a turn off-on of the watch, then it return to normal consumption.
    I use one-time timer (no automatic repeating) and when…
  • RE: 6.10 APAC Device battery drain so fast??
    It's seems fw 6.10 for APAC Device fenix 6, if using activities there is battery drain issue in software. I haven't test it yet for swimming either.
  • Extreme battery drain after update to 6.90
    Just got the update to 6.90, but my battery drains like crazy now. When I just woke up it was suddenly at 5%. Didn't have any issues before the update and had just charged it.
    Please Garmin, give us the option to prevent your updates!
    Btw, that can…
  • RE: Garmin Connect for iOS Battery drain
    It's in the top three, but doesn't really use a lot of battery.
    Doesn't affect my phone life much at all.
    I've seen this frequently too. It's not the same as using a lot of battery. I always see GCM at the top but…
  • RE: Overnight Battery Drain - Even on 5.33
    All the watch faces that I have are made by Garmin. I don't have any third party watch faces. Restarting the watch does fix the issue, until I charge again. I believe that charging the watch using a computer seems to cause to cause the battery drain versus…
