I noticed that the recovery time and VO2Max numbers are not consistent between the default watchface and the performance metrics screen.
In my case the default watchface values are correct but the performance metrics screen not.
Have you seen this?
Have you seen this?
Updated June 26th, 2023:
Engineering has been made aware of the issue to resolve it as soon as possible.
If anyone is experiencing the same issue, please highlight my name and send me a Private Message…
Thanks Chris!
At least aleksiz
So, this morning I've checked again and on the Performance screen, VO2max marker is +1, recovery time marker is -3hrs (i.e. it shows a shorter recovery time on the Performance screen).
It's possible…
If anyone is experiencing the same issue, please highlight my name and send me a Private Message. Thank you!
I recognise that second screen, but for the life of me can't remember where it is/how to access it - can you remind me how to access it and I'll check if mine's showing the same?
Long press the start/stop button.
Thanks Chris!
At least aleksiz
Oh yeah, I remember now! Strangely, my VO2max and recovery markers are consistent between the two screens.
Thank you for your update. If you happen to catch them not aligned, please let me know. I will get you added to the tracking case. Thank you!
It's possible the VO2max marker was actually 1 out when I looked yesterday, it's quite hard to tell just +/- 1, but the recovery time was definitely not 3hrs out then.
Hi Chris, it’s not letting me send you a PM but I notice the same issue . My vo2 max does not match what’s on the default watch face .
Another weird observation in the performance metrics screen. I've seen this now a couple of times.
Today I went for a run and you can see that today's VO2Max value is drawn on far left rather than on top of today's day (Tuesday). Most probably tomorrow again today's value will be above Tuesday.
I hope they fix this soon, really would like to see my current vo2 max on the watch face like it supposed to.. Very expensive not to work right out of the box ..
