Instinct Solar paired with iPhone 11 Pro on iOS 14.1 using Connect 4.36.0.25. The temperature on the weather widget does not change unless I manually sync with the iPhone, is this the expected behavior? If so, it's practically useless.
The iPhone iOS and Connect Mobile must both push the update to your Instinct Solar. Meanwhile, IOS is also balancing battery life on your iPhone to improve it. The best way to approach this is to keep…
The GPS satellites send position data information along with time/date information but not the type of data that weather falls under. Consequently, this is why weather comes from your smartphone…
Same here, iPhone 12 Pro on IOS 14.4.1 and Garmin Connect 40.40.0.28. Would be interesting to find out the weather app data “source” as I’m not sure if it is using the default IOS weather app. …
Garmin SW is really bad - I have everything switched on, active, online, iphone connected, and no weather update even if all privacy, location, data, everything is on and ok, but the only option how to sync new westher to my expensive Garmin Tactic Solar watches is to restar Garmin watches - really?! - this is very big fault of Garmin team !!! I need to make restart every time I change location to see local weather - really bad. Next time I will buy Apple Watch as they are 1000% times more reliable and stable in compare with this product full of SW bugs :-(
I was hoping this would have been resolved by now. I had a Quatix 6 this past winter. Used it in Florida on my vacation , and came back to Michigan where it still read the Florida weather for weeks. Returned the watch…hope Garmin can fix it as I have Garmin gear on my boat….
Let's hope you'll have better luck. Google shows a similar amount of forum posts and troubleshooting tips for problems with weather at the Apple Watch too: apple watch weather does not work - Google Search
