My Instinct 2S is still at 12.25. Auto update is on and no updates seem to be available. What can I do?
What can I do?
If your watch is an Asian model (resp. APAC), then you'll need to wait till Garmin Asia releases an update (and it can be long). If it is the standard model, then you can connect it with the USB cable to a computer with Garmin Express and check for updates there. You can also side-load a beta firmware version manually - you'll find it in the Beta Program section of the forums website.
It is not an Asian model. I was about to try Garmin Express but the update showed up on the watch the same day and I was able to install it.
Don't understand why there waa such a delay. And why we cannot see and select available updates.
