I did not see an option to turn off in settings. Is there a trick to keep the watch in full mode but have the backlight off during sleep? I’m using sw 7.03
Not sure I understand. You have the backlight permanently on during sleep, or do you want to disable it completely? Normally, the backlight is on, only when you press a button (or turn on by the gesture), and normally it is especially during the night that you may need to look at the watch with the backlight on, so I do not think it would be wise turning it off completely, without any possibility to see the display in the night. Or is it really what you wish to have?
there are some new settings I’m not familiar with
last night at around 2330, my backlight kept coming on with button press and gesture even though all my backlight setting are set to “off”. I do not have a setting option in > backlight > during sleep > to turn off backlight like i
see screenshot-
Your issue is a known issue that are engineering team will be resolving as soon as possible.
Here is the main Instinct 2 forum thread that will be updated once resolved:
