Backlight comes on with gesture with ALL backlight options set to off (Please no comments on wrong settings, have used plenty of Garmin watches including the Instinct)
I think it may be limited to after sunset to sunrise only? Annoying.
Yup, mine does the same. Light doesn’t switch on with every wrist gesture, but definitely does come on automatically sometimes. All gesture settings set to ‘off’. On firmware 6.12.
I can confirm this too, not sure what it triggered. There is a setting for during sleep, you can only set brightness and timeout, maybe thats the problem?
Looks like it is, as suggested, connected with times set for sleep. It is ONLY during these times that my backlight comes on automatically with a hand movement/gesture, which I definitely do not want!…
Just tested this and not able to reproduce. Are you on firmware 6.12?
My backlight does not change the intensity at all. Also the flashlight does not work? Or I have a dummy unit?
Looks like it is, as suggested, connected with times set for sleep. It is ONLY during these times that my backlight comes on automatically with a hand movement/gesture, which I definitely do not want! Obviously needs updating so we can select on or off for backlight gesture control during sleep!
Updated June 27th, 2022:
The issue has been resolved with software v8.64.
I have now solved this problem, at least on my watch! Hopefully will also work for others having this problem.
The answer seems to be to make sure that ‘Do not disturb’ is set to ‘on’ during sleep.
Have tested this numerous times and can confirm it works (for me at least!). Now no more annoying ‘gesture triggered’ light during sleep hours!
would be interested to hear if it works for others!
Tony.
I have my gestures set to off for activity and general yet the backlight still comes on everytime I move my wrist. Any help would be appreciated.
