Garmin Fenix 8 Pro ITA
Ieri è uscito ufficialmente il nuovo Garmin Fenix 8 Pro, peccato che sul sito Italiano ancora non ci sia traccia, e non credo sia un problema di versione "Europea", visto che siamo l'unico sito dove non è presente..  qualcuno sà di informazioni in merito?
  • Well, it seems like a wise thing to do since there was the same problem with the 945 LTE, and it came out only 3 years ago, what do you want in 3 years it was very difficult to solve the network management problem. I got tired and after 10 years of Garmi I switched to Suunto, at least I pay half as much.
  • LTE-M global coverage remains quite limited
    velosiot.com/.../
  • Guys, good morning, one last question. I currently have an Italian inReach subscription that I use on the Montana 710 and can transfer to other devices like the Mini. If I were to buy an Fenix 8 Pro in France, since it looks like it will take a long time to arrive here in Italy, and then transfer my inReach subscription to the F8 Pro, do you think LTE will work in Italy? Thanks everyone for your help
  • If I understand things correctly, these new watches use LTE-M networks, not LTE, also known as 4G. And according to the link just above your comment, there is no provider for LTE-M in Italy yet. So my guess would be that it won't work, but the In-reach part should. Probably why Garmin decided to not launch the watch in Italy until it doesn't work there.
  • isn't this an obsolete technology? I doubt there will be any changes in this regard.
    Maybe Garmin will update to 5G in the next devices
  • I don't claim to be an expert on this, I just looked some stuff up, but as you can see from the link in 7000518's comment, even LTE-M's deployment is not complete in Europe, and the next generation for this is called 5G NR-Light (RedCap) was standardized only in 2022 and there are only experimental networks supporting it in Europe.
    These are not the same as 4G/5G standards, they are low power networks for wearables, industrial applications, smart meters, IoT devices, etc. that can receive/transmit data with a lot lower power requirements.
    So I think it's like WiFi... even though there is now WiFi 7 as a standard since 2024, you won't see Garmin watches that will rely only on WiFi 7 for a long time, as most people don't have compatible access points at home.
    Same with this... it will be quite a few years until the 5G NR-Light networks will have a global coverage so that it makes sense to release a watch that uses it.
  • It is quite confusing, because on that link LTE-M there is no coverage on Italy/Portugal. But Garmin Fenix 8 Pro supports LTE in Portugal. And on the other hand Fenix 8 Pro does not support LTE in Czech Republic but it is still sold there unlike Italy.
  • It's new tech for the IoT, garmin is piggy backing for comms
  • Scelta curiosa di non venderlo solo in italia ma se proprio si vuole esiste amazon e si compra la.  un po le ultime scelte di garmin ultimamente  che sono state fatte lo sono. Oltre al dispositivo (1000€) dovresti pagare almeno 3 abbonamenti per sfruttarlo a pieno ( connect +, outdoors maps + che non funziona e inreach ) quindi sono almeno 120/150€ all anno in piu. Mah!
