Hi everyone — this is the canonical thread to collect short, low-effort reports about the Fēnix 8 AMOLED extreme auto-dimming issue and coordinate a single, documented request to Garmin.
Short problem: In low light many Fēnix 8 owners report the display auto-dims so much it becomes nearly unreadable even when brightness is set to maximum. Garmin’s current reply has been “by design.” We believe this can be fixed via firmware (manual brightness override / raise minimum brightness).
Goal: Gather simple reports to demonstrate scale, then send a consolidated request to Garmin Support. If needed, create a petition and run a short social push (#FixFenix8Brightness).
Two easy ways to help — pick one (do not need to do both):
A) Quick & preferred (takes <10s) — post one short line here:
That’s enough to be counted — photos and firmware are not required. If you prefer anonymity just write Anonymous.
B) Optional (1–2 min) — structured report + optional photo/video — fill this quick Google Form (optional):
https://docs.google.com/forms/d/e/1FAIpQLSeE9Ngye0eWSI-PH99lkD7lK7L7fopIJyrwY1fFNChMaJ9KWQ/viewform?usp=header
The form allows optional photo/video upload and automatically stores entries in our sheet. Filling the form is optional — posting one short line in this thread is sufficient.
If you already reported to Garmin, optionally add Sent to Garmin: YES after your line.
Example reply (copy/paste):
fenix 8X — Screen nearly unreadable in dim room even at max brightness. Sent to Garmin: NO
What we (organizers) will do next:
After ~2 weeks we’ll compile short replies and form responses into a summary list.
If there are many reports, we’ll send a consolidated feature request to Garmin Support with representative photos/videos.
If Garmin’s response is unsatisfactory within ~14 days, we’ll start a petition and coordinate a one-day social push (#FixFenix8Brightness).
Privacy note: We will not ask for serial numbers or personal data. Photos and firmware are optional. The aim is to show scale, not collect identities.
If moderators can pin this thread as canonical, please do — it will keep everything in one place. Thanks
