Feature Request: toggle headphones on or off
I'd like to be able to easily select or toggle my headphones on or off.  The only way I found to do this is buried in the settings.  On new blue tooth headphones, I can take control or connect from a different device e.g. phone if the headphones support multiple connections.  On some headphones, especially older ones you must first disconnect your headphone from the currently connected device before you can connect the headphones to a new device.  If I have multiple headphones or earbuds connected to my watch.  I want to be able to change connections,  Presently, I still need to find the audio selection buried in the settings menu.
Is there a way to add the blue tooth headphone selections option to the controls menu?  Or, is there an IQ app that I can add to my quick access menu so I don't have to spend time searching the settings to find my connected device.
  • If you turn off your headphones, they will disconnect from the watch. And the watch won't re-establish the connection until your start music on your watch or do something else that requires a headphone connection, like breathwork or connect manually. (At least that's how it is on my current Forerunner 965 and was on my old Fenix 5+).
  • This might work for my headphones but not my earbuds (no off button).  Also, when I go to the gym I connect to different stationary bikes depending which is available.  It would be nice to have the sesor menu easily accessible.
