Turn off sleep mode automatically
My Fenix has sleep mode automatically between 22-06 (10pm-6am).
I don’t want this.
The watch should always track my pulse and everything. And not change anything at all.
I can’t se how I switch this function of (its activity and sleep).
Top Replies
All Replies
  • Here's the manual:
    www8.garmin.com/.../GUID-1F1B3DBB-02F4-4D96-8D3E-AC278D45BACD.html
    You cannot turn off the sleep mode, but you can set it for just one minute, for example from 08:00 to 08:01. But your watch always track your pulse and everything, if not set otherwise. But you will have gestures, full bright display, notifications, sounds, vibrations even in the night.
    So why do you want to turn off the sleep mode?
  • Hello
    Unfortunately, while you can disable the sleep mode in the morning manually each day, it is not possible to disable sleep mode entirely. So for Sleep mode, you will want to set the schedule to most closely match the times you are sleeping.
    You can however control how the watch behaves during sleep, to continue tracking HR etc. This can be done using the Sleep mode settings and Focus Modes.
    For Sleep mode settings:
    1. Scroll through widgets to Sleep Score
    2. Select Sleep Score
    3. Press the Upper Right button
    4. Select Settings
    5. Be Sure Battery is off
    6. Adjust other desired settings
    If you have Battery Save enabled, you will want to adjust settings for allow HR during sleep etc:
    1. Hold the menu button
    2. Select Watch Settings
    3. Select Power Manager
    4. Select Battery Saver
    5. Select Edit
    6. Adjust the desired settings
    You will also want to ensure you Focus modes during Sleep are set correctly:
    3. Select Focus Modes
    4. Select Sleep
    5. Adjust the desired settings
