Fenix 8 erratic behaviour. Should I reset or factory reset? Does backup and restore really work? How to prepare? Thank you!
Fenix 8 51 Amoled. Best way to restore normal behavior without losing settings?
Top Replies
  • Hello
    I am sorry to hear you are having this issue. Whether a factory reset is warranted, really depends on the issue you are experiencing. Here are some things to consider.
    • Is the watch on the…
All Replies
  • Hello
    • Is the watch on the latest software version? If not, I would recommend updating this using Garmin Express.
    • Are you running a BETA software? As these are in their testing phase, they may introduce bugs. You may consider rolling this back to the previous full software version.
    • Since the issue started, have you tried a powercycle? If not, I would recommend trying this.
    • If this issue is with a specific activity, you may consider restoring the activity settings first.
    • You can also try reinstalling the current software version with these steps:
    1. Hold the menu button
    2. Select Watch Settings
    3. Select System
    4. Select About
    5. Select Reinstall software
    If the issue continues, you can try a factory reset with the steps below. However, you may also consider settings and a backup and restore, to avoid losing your settings. **it is important to note that if there is a software error, backup and restore and reintroduce this error to the watch. So if you issue resumes after restoring, it may be necessary to factory reset without restoring your settings***: Using the Back Up and Restore Feature on Select Garmin Watches
    1. Ensure the watch is powered off.
      • You may need to hold LIGHTfor up to 30 seconds to turn the watch off.
    2. Press and hold BACK and START/STOP.
    3. Press LIGHT to power the watch on while holding these two buttons.
    4. After the first beep release START/STOP.
    5. After the second beep release the remaining button.
