Synch with Garmin Explore add 1000 positions in the Location Folder. I delete one by one but... Can I just delete the Location folder in the fenix 8 ?
Maybe, it might be automatically recreated by the OS.
You could try deleting and then recreating yourself.
FYI, there is only 1 file in my locations folder - lctns.fit 4.12 KB
You can and all the locations will be deleted from the watch. You do have to be careful that if you delete waypoints from the watch, the next sync with Explore may delete the waypoints in Explore also.
Thank you , I remove thé Watch from Explore.
Then you have not sorted your collections correctly. Select the relevant collection that you want to synchronize.
Correct. That is why the waypoints should not be deleted, but sorted into a collection in Explore, and then the corresponding collection in Explore should simply be deselected from synchronization. They are then deleted from the watch after next sync, but are not lost and are still available in Explore.
here the web manual (app logic is the same) :
https://www8.garmin.com/manuals/webhelp/explorewebsiteInd/EN-US/Garmin_Explore_Web_Help_EN-US.pdf
No need. You only have to manage your collections.
