Hi there!
What are your experiences with the voice commands? Offline and Online? Do they work properly? What about Google Assistent? Does this work aswell? no issues?
Thanks alot for answering!
Cheers
Marc
Hi there!
Cheers
Marc
I just use it to set timers maybe 2 or 3 times a months. And many times, it sets the wrong timers. For some reason, when I say 40 minute timer, it always sets it to 4 hours. The voice commands seems like…
It is very sensitive on background noises. But when it is quiet and you speak clear it works for me almost every single time.
Sure it needs ~5 seconds to process your command but it is still more conveinient…
Ho appena preso Fenix 8 51 mm e lo sto ancora testando. I comandi vocali sembrano funzionare abbastanza bene, se provo ad avviare un'attività o un timer non ho problemi. L'assistente vocale funziona bene…
I use the voice commands to set timers regularly with great success, not much else. It seems to use Siri it's a little laggy and not very smooth.
I use the voice commands on the watch countless times to set timers which really works fine.
Beyond that I have to admit that's it. When I want to start an activity I prefer to just press the buttons.
But for the timer it is a great user experience not to set the time manualy.
The voice assist (google) I use most of the time to set new appointments and reminders.
Works great for me as well.
I just use it to set timers maybe 2 or 3 times a months. And many times, it sets the wrong timers. For some reason, when I say 40 minute timer, it always sets it to 4 hours. The voice commands seems like it was rushed, not fully baked feature.
thanks alot for sharing your experience about it! appreciated!
Like most people, for setting a timer. It takes ages to function, and regularly gets it wrong. Voice command is dreadful. That said, I'm not that sold on talking to a watch.
Sure it needs ~5 seconds to process your command but it is still more conveinient than set a timer manually.
I wish they would build a custom command set, from customized activities, this is a big one for me. I have an old Edge 830 that doesn't log Intensity Minutes, so I co-start a no-GPS cycling activity when I go for rides (linked to same HRM strap), so I get "credit" for those minutes (otherwise it's very hit-miss).
I can use it to start say a Walk Activity, NP, but if I try to do a "Bike No GPS", that's a lost cause, it either just fails out or kicks me into MMA sport mode, hmm...
I've used it for a few settings things, as a test, those seem to work reasonably well (I'm very good at speaking to most things audio-assistant, I ran a dev/PM team on a voice implementation for a bit, as a tech-PM, you get VERY good at this for repro type stuff... ).
It sounds like it's not ready yet...
Ho appena preso Fenix 8 51 mm e lo sto ancora testando. I comandi vocali sembrano funzionare abbastanza bene, se provo ad avviare un'attività o un timer non ho problemi. L'assistente vocale funziona bene per me , avvia chiamate e altro senza problemi per ora. Una nota dolente è il volume troppo basso dello speaker l.
