Hi everyone
I‘m trying to figure out if it works or not. I found a very small amount of posts that it works, but there is also a lot of posts around the net that it doesn’t work.
So what’s the deal in Feb 2025? Does it work?
Hi everyone
For clarity, you're asking about whether you can answer a WhatsApp call via the watch and then use the watches mic and Bluetooth connection for the audio?
Been using it since Fenix 8 release. On iPhone it works fine. I can answer the call and talk through the watch. Very clear. The only issue is that there is slight delay from when you press a button on the watch to answer and when it activates the call. Maybe 2-3 seconds delay sometimes. This delay is also on regular calls. Other than this delay it works beautifully. Very clear and as loud if not slightly louder than AW Ultra.
