The Always on display is disabled and I can’t turn it on back.
pleases advise how can I enable this feature.
thanks
thanks
Hello. I am sorry to hear you are having this issue. Do you have Battery Saver enabled? If this is enabled, Always on Display option will be grayed out.
Assumed I did it allready but perhaps not. Rebooted and all good, I think. Thanks!
My Forerunner 970 just started doing the same thing. It’s been enabled for months but now it’s greyed out and I don’t know why.
I am sorry to hear you are having trouble with the Forerunner…
I am having same issue. I just bought my watch about two weeks ago and the “Always on display” setting is greyed out and I cannot enable it.
Have you had any luck?
I am having the same issue. I just bought my fenix 8 about two weeks ago and the “always on display” setting is greyed out and I cannot enable it.
Any luck finding the issue?
Bought this watch two days ago and having same problem. Battery saver is not enabled. Is there an issue with this watch? How can I return to "always on"?
Edit: Figured out why. The “Always On” had accidentally been turned off on the watch itself and it apparently overrides the app. Seems like they should show the same thing and you can turn it on or off from either one.
I’m having this same problem out of the blue on a Forerunner 970. It’s been enabled for months and now the setting is greyed out for no apparent reason. Battery saver is not enabled.
I am sorry to hear you are having trouble with the Forerunner 970. You will want to be sure to post these concerns to the Forerunner forum here: https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-970
Same issue here. Changed few days ago, not sure perhaps with 17.28 update. Wake On Gesture doesn't work either. Same with or without Battery Save mode.
Rebooted just now and all is working again. Wake on Gesture and AOD is not available.
