Good afternoon. When an external Tempe sensor was connected, Fenix7 showed the temperature detected by the sensor. Fenix8 shows the temperature from the internal sensor. Can this be fixed?
During the activity, everything works as it should. I'm interested in the temperature readings in the normal mode. On F7, the widget shows the temperature from the sensor always when it is connected to…
I am trying to recall if the Temperature Glance on my Fenix 7 showed the Tempe data. I seam to recall I needed a 3rd party app for that. I just tested an app on my Fenix 8 and it did show temp from the…
Thank you, it's working!
I am using the maca88 Tempe Field app. It works well. It records Min, Max and Avg temp from the Tempe in any activity I added the field to.
For example, Walking has a screen with the Tempe Field added. Below is data added to the Walking Activity:
I am trying to recall if the Temperature Glance on my Fenix 7 showed the Tempe data. I seam to recall I needed a 3rd party app for that. I just tested an app on my Fenix 8 and it did show temp from the internal and Tempe sensors on the screen. That app did not appear to graph both.
