Fenix 8 Solar 51mm firmware 12.35 battery drain
Hi.
I have had Fenix ​​8 since 4.12, before that I had 7. Since new, the battery went from about 65% to 15.12 went down to 15% and I decided to charge and update the watch today. I exercise every day, about an hour - 4x running with GPS, 3x gym. After charging it fully, from 13 to 18 the watch went from 100% to 95%. Has anyone noticed similar battery consumption at 12.35?
  • I think sometimes, the reset clears out the physical memory and RAM resulting in fewer more efferent handoffs of data in the OS which will help in battery life. Speculation on my part.
  • I followed your lead, also master reset. Did you restore a copy or reconfigure from scratch?
  • Hello. I am sorry to hear the battery is draining too quickly.
    Our engineers are still investigating battery drain concerns associated with the Fenix 8. They would like to point out many things that are expected to increase battery drain beyond the estimated days remaining. This could include any of the following:
    • GPS (in particular All satellites, or Multiband settings will use more battery life)
    • Voice Features
    • Phone assistant
    • Backlight (It is recommended to reduce the brightness. Gestures will turn this on more frequently)
    • Notifications
    • Alerts
    • Vibrations
    • Animations (as with yoga or breathing activities for example)
    • Connect IQ apps or watch faces (many of these have been found to drain the battery more quickly)
    • Pulse OX either All day or During Sleep
    • Paired sensors
    • Music
    • Paired Bluetooth headset
    • Watch faces with second hands
    So when you are measuring your battery drain, be sure to take these items into account. If you are seeing a rapid drain, please feel free to reach out to me via Private message so I can collect some details.
  • Hope Garmin will fix it soon. I‘ve Never seen a 1000$ watch which had only 50% of its adversed battery life 28days vs. 14 days in general
  • I have the non-solar edition fenix 8 (47mm) and since 12.35 I have a huge battery drain than before this version. Charged it today to 100% and 6 hours later the capacity is down to 90% with just a 15min HIIT workout done.
    I do not use any Connect IQ Watchfaces, no Voice Assistant, only iMessage- and health-notifications enabled. No PulseOx. 1 alert in the morning, no music, no animations, no always on display (only in workouts)
    Previous the last update I did min.1h gps workout (running) daily and same settings otherwise as described above and after a week battery was down to 50%.
    With this huge battery drain the Apple Watch Ultra I had before was similar with more going on beside sports…
    Any ideas how to proceed? Any news on updates?
  • Yes !!  There is definitely an issue with 12.35.  I have the Fenix 8, and ever since installing 12.35, battery drain has been terrible.  30% or more / day - even when barely doing anything.  Previously it was the 5-10% range / day.  From what I've read in other forums / boards - the theory is GPS or some activity is still 'running' even when you've stopped that activity.  The only way that's been shown to help is to reboot, which likely kills that process.  Hopefully Garmin can figure this out and get us an update.  Having to constantly reboot a $1000 watch to prevent battery drain is not a good solution.
  • I’ve lost about 2 days of battery life after the 12.35 update. Before that full charge prediction was 16+ days on 47mm amoled, now it is about 14 days and it seems to be consistent with the actual discharge. I did factory reset and then restore from backup to make sure that the settings were preserved between updates.
  • Hi,
    I have a Fenix 8 (47mm) running Software 12.35, and I’ve noticed significant battery drain since last week’s update. It dropped from 100% on Monday evening to 14% by Saturday morning, with no changes to my usage—3 workouts as usual and no setting adjustments that could explain it.
    I restarted the watch a few times because the heart rate seemed inaccurate during training. After charging it yesterday around 17:00, it’s already down to 92%, which still feels faster draining than normal. I usually get 16–18 days of battery life.
    This seems linked to the recent update. Is it possible to revert to an older software version?
    Kind regards, and have a great Sunday!
  • My battery is noticeably draining faster, than before 12.35. A fully charged my 51mm watch yesterday morning, had just one walk with dog and today it shows 94%, 27 days remaining...
  • Batterieverbrauch seit Beta 13.25... ohne GPS von 4%/Tag auf 8%... F8/51 Solaranlage... Bin ich allein?
