When AOD is enabled and battery saver is on, the screen shows the Garmin logo, the battery and the date but not the time even with AOD is disabled. Anyone else?
Update March 24, 2025: Our engineers are still investigating a concern with the AOD remaining active when disabled in battery saver settings. I will update here, once there are further updates.
Our engineers have indicated that there is a fix for an issue that may cause the battery saver display to show overlapping or missing time. This was included with the 13.31 SW update…
Update December 20, 2024:
Our engineers are aware of the a concern that may cause the time to overlap or disappear, while in battery saver mode. This is being investigated for a software solution.
There are 2 bugs here. First one:
- The low power watch face is broken: likely the time is there but the font is also black
- You should be able to keep your current watch face in Battery Saver settings…
They need to fix Focus mode, because it's causing problems. But no one here is listening. And if you can't, remove it and go back to the settings from Epix/Fenix 7. More bugs than benefits...
If they don’t listen to Garmin-Laurie, how are they going to listen to us?
Version 15.31, the upcoming release now in its final stage with ECG and Dive enabled, does not fix this error. This issue was reported over six months ago, and according to Garmin-Laurie, the engineers were already working to resolve it... So it's either that the error — which seems simple — is actually too complicated to fix, or, I'm afraid, Garmin-Laurie, that they don’t give a damn about what you say either, just like they ignore their customers. Whatever the problem is — incompetence or indifference — it’s disheartening for all of us.
After a year and numerous reports with each new version, this still doesn’t work properly. When I enable battery saver mode, AOD doesn’t turn off. Will you ever manage to fix this?
Confirming it's not working. Battery saver is mostly useless without this
Garmin-Laurie still not working in 17.28
