my Forerunner 935 showing signs of moisture ingress around edge of glass cover _ anyone else? Solution please
Hello 2855546
I am sorry to hear the watch is showing signs of water ingress. As @trux mentioned, this likely means there is damage to the water proofing seal, so you will want to avoid contact with moisture…
Im just curious, how did you manage to post this in Fenix 8 category?
The Forerunner 935 has been discontinued.
Also, we are fenix 8 Series watch Users here, so...
Put it into a container with silica gel, or rice, and hope it dries out. You could…
Put it into a container with silica gel, or rice, and hope it dries out. You could also disassemble the watch (find a tutorial video on YouTube - there are a few ones) to ease the task of drying. And when you are at it, I recommend changing the sealing. If not changed, and perfectly clean without any traces of dust, avoid any contact with water. Or go to the local jeweler or electronics workshop and ask them to do it for you (if it is not more expensive than a new watch).
Hello 2855546
I am sorry to hear the watch is showing signs of water ingress. As @trux mentioned, this likely means there is damage to the water proofing seal, so you will want to avoid contact with moisture. The watch will likely need to be replaced. For this, I would recommend contacting Garmin Product Support.
Since forums support for the Forerunner 935 has been discontinued, I will lock this thread. You are still able to look to Garmin's support page for concerns here: Forerunner 935 support page
