UI glitch with industrial watch face
I noticed couple glitches on the industrial watch face.
if you put some data with double digits it will overlap.
here you can see that these circles are not fully aligned.
My understanding is that this is garmin original watch face. Would not expect these glitches.
Anyone else noticed this?
  • hello, i have the same problem, has anyone looked into this please ...
  • Guessing it might have something to do with an AMOLED screen saving technique that shifts pixels slightly on intervals
  • I'm experiencing a similar issue with the steps, timer, and other complications on the Industrial Watch face. The values seem to display randomly. For example, sometimes the step count shows as a small bar, while other times the same number of steps will display with multiple bars. The same issue occurs with the timer complication. If I set a 30-minute timer, the complication shows a single small orange bar, but when I set a 60-minute timer, it still only shows one bar, despite the longer duration. I love the industrial look, but if the functionality is inaccurate or unreliable, it’s essentially useless. For a $1000+ watch, I expect the built-in watch faces to work properly. Garmin, please look into this and issue an update.
