Hello all,
I recently got my Fenix 8 47mm Solar and upon configuring it I noticed that the touch function is not working at all. I tried the setting it up (as per user manual) using all of the following:
- Holding Down and Select (on screen it shows Touch On but not working)
- Holding (for 2 seconds) Light (menu appears I can navigate and enable/disable Touch but still not working)
- Going into Watch Settings -> Display & Brightness -> Touch ON (still not working)
In all above settings the function Touch Lock is set to Off. I even tried to reset the Fenix to factory defaults, did update to 11.67, restarted it multiple times, nothing works.
Maybe some of you had a similar experience that might share a workaround or a fix for this?
PS: I could not find a touch calibration menu and, on this forums I could only see a thread for buttons calibration (on AMOLED version) which I have not tried yet.
Any help is much appreciated.
