Watch turns off and reboots in cold water
As per the subject
It won’t work in water below 10 degrees. You can replicate this by putting it in a glass of cold water for a minute, pulling it out and noting the watch turned off.
Watch flashes between music mode then just turns off entirely.
Anyone else do icebaths and have this problem? The other issue is Apnea training in a cold pool. Does it there too.
Note: if anyone else is going to try the cold water test, I think the watch detects if it’s not on your wrist. If AOD is enabled the screen will turn off regardless so don’t confuse the screen turning off with the watch failing.
For a watch that is MIL-STD-810 tested, this is a very basic test to fail……..
