Hi.
Does it work for any of you to say ‘Lap Alert’ correctly in the secondary field?
I have the default ‘lap time’ set in the primary field and ‘average heart rate’ in the secondary field (I also tried ‘heart rate’ alone). After a lap, the lector says the time of the respective lap correctly but no longer says the data (heart rate) from the additional field absolutely.
Just before writing this post, I carried out a test by swapping the contents of the primary and secondary fields, i.e. I put ‘heart rate’ in the primary and ‘lap time’ in the secondary.
Slight surprise - this test showed that after a lap, the lecturer pronounces the content ... of the secondary field, skipping the primary field.
So the conclusion is: after a lap, the voiceover only utters one message and that is only ‘lap time’.
regards
Artur
