it's already the second time that my fenix 8 crashes while I'm starting a task and shows a black screen with a blue triangle! Fortunately, I can force a reboot to get it going again. Did it happen to anybody?
Hello rtapiste
I am sorry to hear you are still seeing this issue. Have you installed the 11.89 update? If not, please use Garmin Express to install this. Then once this is installed, complete a hard reset…
Yes, it happens to me too, sometimes when I scroll up-down on notifications, sometimes when trying to start an activity and sometimes completely random when just in watchface. The Garmin triangle appears…
Mine crashed today for the first time after i saved activity ( hike + course navigation) watch petformed unexpected reboot. Activity including stats got saved.
Same here ! It crashes when I launch a benchmark run created by Garmin Coach. Felix 8 it’s my first Garmin so far bad experience.
I have two notices
The first is that this issue didn’t show again with my new fenix 8 51 which was purchased for the second time just to change the color of watch, I Sold the previous orange one to my friend, I didn’t hage any issue with new watch,
The second is I noticed that this issue is happening only if jumped into the ice pool right before I jump again to the swimming pool, I guess exposing the watch to extreme cold water or weather mat have some effect on it, so the system is frizzed until you force restart again
Yep, same thing here since today. I'm on SW. 12.35
Today again two crashes even aduring pool swimming when timing my laps and during checking Stock glances..So crashes occur not only during GPS activities.
Very annoying, pls fix
Tengo un problema similar, se apaga y tengo que encenderlo continuamente, me han mandao un listado de carpetas que tengo que borrar dentro de la memoria, pero sigue dando el mismo fallo, es frustrante.
tengo un problema similar, se apaga continuamente y tengo que encenderlo, he seguido las instrucciones del servicio tecnico y no se soluciona, es frustrante.
