Fénix 8 amolde 47mm keeps changing screen alone
It happened like 1-2 everyday. I’m at work moving and doing stuff and when I look to the watch I find it deep in some menu. Changing the widgets or inside the map of weather, like it has gone inside the menu.
I don’t really know if it goes through the touchscreen or by the buttons but it is annoying…
anyone suffering this?
Top Replies
  • Hello
    I am sorry to hear you are having this concern. Have you tried enabling the Touch lock?
    To lock touch screen during General use:
    1. Hold the Middle left button
    2. Select Watch Settings
    3. Select…
All Replies
  • I have not noticed this yet. As I understand it, the buttons are inductive. If the watch is subjected to a strong electromagnetic field, I wonder if a button could trigger?
  • Hello
    3. Select Display and Brightness
    4. Ensure Touch lock is enabled
    To lock touch screen during Activities:
    3. Select Activities
    4. Select the desired activity
    5. Select the activity settings
    6. Select Touch Lock
    7. You can set this to On, Or Don't Change if you have this On for General Use
    When the display is locked, to unlock this, you will just swipe the Lock icon down the middle of the display.
  • Yes, it’s a sensitive touch screen… gotta lock it!
