How to update maps without Garmin Express?
There's a few reasons why I might want to do that:
  • Linux on my laptop
  • backdated software but Garmin Express will update software before updating maps
  • glances folders messed every time Garmin Express synchronizes
Can I perhaps download the gmapsupp.img or whatever it's called file and transfer it manually? Am I doomed to stay on old maps simply because Garmin seems unable fix their crappy software?
  • I've tried running Garmin Express myself on Linux under wine, but that simply will not work.
    Also tried to make a remote-desktop connection to a Windows computer at work, forward my garmin USB connection there and although Windows then sees a Garmin device, Garmin Express simply fails.
    Sharing my WiFi connection with my watch and then download the maps over WiFi takes hours and hours and then fails just before it should finished which also feels like a huge disappointment.
    It's not the answer you are looking for, but I ended up downloading a few Garmin maps from this website: https://garmin.opentopomap.org/ and manually copying them to the GARMIN folder on my watch and naming them gmapsupp.img gmapsupp1.img gmapsupp2.img etc.
    It's not the official Garmin map, so maybe that's why the rendering is not optimal, not sure, but at least I can see where I'm going now Slight smile
    hope this helps
  • Garmin Express will update software before updating maps
    That sounds strange. I do that all the times with my 15.77 live system and while GE is indeed copying the new software file to the /Gamin folder as soon as you connect you could either deny "perform update" when prompted after disconnect from PC (I have automatic updates disabled at all times) or - even better - you could delete GUPDATE.GSP from /Garmin before you proceed.
    That happened to me too but only if I enter the section where you can configure it, when I just connect to GE and update maps this doesn't happen. Which FW are you on?
    What region do you need?
  • Okay, your reply encouraged me to try Garmin Express again. I've been avoiding it for a long time, so I don't exactly remember what FW version I had when it last messed up my glances :-)
    Anyway, I started a fresh Windows 10 VM, installed Garmin Express, and did nothing else than let it update the maps. And hooray, it did not mess the glances up!
    I'm still a little worried what happens if I boot that VM in a couple months time and let GE do its stuff, because it does attempt to sync the watch with Garmin Connect, as if it was early 2010s and the watch couldn't do that on its own through the phone connection. But I guess I can wipe the VM and start from scratch in a year's time and hope everything's good again.
    Thanks!
  • Yeah the wifi map update is a complete joke. I tried leaving it for half an hour, it stays on 0% and then fails anyway.
  • Windows 10 VM
    That's what I do. I never experienced problems resulting from the fact, that I start the VM every month only. Also you may want to take a snapshot...
    Also I suggest you either prevent GE to start up automatically or to stop it every time before you connect your unit. After that I suggest to do a full copy of /Garmin before you let GE go and an copy after. So you can at least compare.
    While you are at it, this might be handy:
    forums.garmin.com/.../information-restore-settings-after-factory-reset-w-o-syncing-possible
