On a Fenix 7S S/W version 16.22, I get 2 new records set (1k & 1 mile) screen appear after every run it seems, even though they are not new time records. Does anyone else have the same issue or know the cause?
Did you accept the records in Garmin Connect?
As long as you do not accept the new record, each time you reach the same weight (or time, or distance), it will be detected as a new record again (since the original one was not accepted).
Better told…
I guess I should’ve included that I accepted the original record and that every following record with the same weight was ignored.
If I understand you well, then that's the expected behavior…
I didn't know about that. I went there today, and the new records to be accepted don't show. Do they disappear after a while? It was only about 8 hours ago that I did an activity with new records notification.
Found what’s wrong with new records on the Strength app. After an exercise with an assigned weight from a custom workout created in Connect, the weight gets added a 0.1lb afterwards. When doing my PR weight I would get a New Record message in watch but the decimal wouldn’t be shown, hence why I thought it repeated it. In Connect app I could see the added decimal in the completed activity, even though the custom workout doesn’t have it. trux
(Miss-clicked on report)
