My Bezel was scratched really bad so I removed the Black coating and polished the titanium a little it came out way better the expected.
Well, finally finished my polishing job. It was no 15 minutes but a couple of hours, better take it to a jewelry to do it. Started with manual sanding, no luck removing the anodized paint. Got a cordless…
I did that first it looks way better polished and it only took me 15 minutes the amazon bezel from the side did not look right it looked like you had a second piece of steel stuck to the bezel
Great job! Looks better than an original
Stainless steel bezels are 15 bucks on amazon.... less work
Looks excellent, almost like a factory job. What did you use to polish the bezel?
400 grit sandpaper then 600 grit then diamond polish
Falls off in 5 minutes
Will that work with non titanium case?
Btw, how do you pronounce your nickname?
Looks great, did you use any machine to polish, or by hand ?
well, mine lasted 20 days... it was missing today after wake up..... so after all it is not a bad idea....
By hand
diamond polish... what grit or microns? I am already looking to purchase, but there are several sizes.
