Hi folks,
Since 10.43 I don't receive any weather data (Garmin Connect via iPhone).
Switch off / on doesn't help.
Did you determine a similar behavior?
Hi folks,
Had the same issue.
Solved it by removing the watch from Garmin connect app, then from BT devices in the phone, and going again through pairing process.
Takes a few minutes, but problem solved. Did not…
Good, check the changelog about the watchface. There has been same problem before, it's not a Garmin problem
That's strange. Do you connect with iOS or Android?
Perhaps the difference depends on the OS used...
IOS, iPhone XS.
Latest GCM and latest iOS installed.
Exactly the same here.
Even more strange. Tomorrow I'll call Garmin's support.
I have the same issue. Have tried restarting the watch and the phone as well. iOS location permission set to always, but also tried a fixed location for the weather data, which also didn’t work.
Fenix 7S Sapphire Solar 10.43
iPhone Xs iOS 16.1.1
Garmin Connect 4.61.1.3
I'm on Android... No problem with weather data... 10.43
Something about the weather has definitely changed since 10.43. Also on Android.
I use a weather widget. That shows me the location where I am. There, before the 10.43, I was always shown my home town when I am at home. Since 10.43, the nearest weather station is displayed as localization. But it is 10 km away.
Had the same issue.
Takes a few minutes, but problem solved. Did not lose any data in the process.
This fixed it for me as well. Takes few minutes, no data lost ++
(one small remark, you have to readd any payment cards you had in GarminPay).
Yepp - your process helped as well. Great!
Mni thanks!
