Hi folks,
Since 10.43 I don't receive any weather data (Garmin Connect via iPhone).
Switch off / on doesn't help.
Did you determine a similar behavior?
Hi folks,
Had the same issue.
Solved it by removing the watch from Garmin connect app, then from BT devices in the phone, and going again through pairing process.
Takes a few minutes, but problem solved. Did not…
Good, check the changelog about the watchface. There has been same problem before, it's not a Garmin problem
I have the same problem. My weather data field in the watchface no longer shows my hometown location. It also shows at home the place where I work.
Otherwise he always changed places correctly.
Until now I have no solution
What watchface are you using?
The name is "GearMin V3". It works until 10.43
But the watchface is just showing the information from the Fenix current location CIQ 3.2.x
Then it's not a Garmin problem, contact the developer. If you read the changelog of the watchface, you can see that there has been problems with the weather data refresh.
And there we are again with the chicken and hen problem. Because the developer says exactly the opposite. I had already contacted him.
This worked for me. Tried everything before...
