the IRNSS has only L5 frequency , there is no L1... (the other is in S-Band but that is a totally different and higher band than the "normal" GNSS freqs, only very special and professional GNSS receivers…
That was a really bad decision on Garmin's side because in my opinion the multi-band was one of the most anticipated features
And those that wanted it could choose to buy it. Those…
Supposedly the same Airoha AG3335M chipset is used in both versions. At least I don't see another multi-GNSS Airoha chipset without L1+L5 support and with all other parameters the same as AG3335M.
…If You're right, it's almost clear, that other "basic" F7 models has the same. But how do You know that??
Edit: SO NOW IT'S CLEAR, WE CAN'T GET IT!
Good catch! Yes, it has unfortunately the AG 3335MN chip (at 7:55 in the video linked above).
AG3335MN only support IRNSS in L5-band.
My understanding is that the chip only works on L5-band for IRNSS (Indian Regional Satellite System) and can work in dual-frequency for the rest of regional satellites systems..So for me, it means it can use dual-frequency (L1 and L5) for most of the countries
It can use dual-frequency in ALL countries, because systems like GPS or Galileo are global, contrary to IRNSS.
My understanding is opposite. That the L5 band is supported only for IRNSS with AG3335MN.
And apparently you can count with your fingers the number of satellites use on the IRNSS
For me the note means that IRNSS only support L5-Band due to its own limitations.
Sorry, I cannot add an screenshot showing the note to allow more people to read it and give their interpretations
Yes, that is clear and no one is disputing that.
But then you wrote, that dual-frequency can be used in MOST countries, which is incorrect, because it can be used in ALL of them.
There you go... Thanks for the correction. I will add that you not only can use it in all the countries, you can use it globally (in the Earth ) in the middle of the Pacific ocean in a boat you can use dual-frequency
For me it's a strange interpretation. The clearer will be: Support IRNSS only in L5
