Hi mates! I have some issues with solar battery in my Garmin. It doesn't won't to take charge and I couldn't fine solution of this problem! maybe somebody had the same problem and can help me? I will be appreciate!
thank you in advance
Does the solar widget show solar exposure? If the solar graph is flat, then contact garmin support. And if not, then perhaps you expect too much from the solar panels. They are to weak to recharge the battery. What they do is barely slow down the discharge of the li-ion battery.
The graph is flat. I intentionally left watches on direct sun light and there was no changes on a graph.
Then try a reboot, and if this does not help, then the watch is broken and needs to be replaced.
My F6 has the same flat line issue Service Sg told me I am the only one with the problem as they cannot replicate it...I think its stuffed.
