After update to sw v.23.00 Fenix 6x don't show sleep data after stop sleep manually.
Updated December 5th, 2022:
Engineering is looking into the issue further to resolve it.
For anyone that can replicate the issue of your sleep deleting if you manually end your sleep recorded for the…
I have the same problem on my Fenix 6 Pro. I don't really want to reset my watch to factory settings and loose all my activities on the watch without knowing if it works. Powering on and off does not solve…
Same Problem here. Reboot and soft reset (hard restart, however you want to call it), which I periodically and definitely always after a firmware update do, didn’t help. Really don’t feel like resetting…
Cool. I've just tried this too with both the sleep widget and the HRV widget and both save sleep data fine now.
Hi Chris, i found another bug.
After manually ending sleep and having a bad previous day, it pops up the information about sleep evaluation and then it can't be removed. Or rather, the "Recovery time delayed" message cannot be removed. The watch works (I can get into the menu, start the activity), but the message remains and I can't get rid of it. After restarting the watch everything is fine.
Tactix Delta on v23.10
