Have a nice day
How can I turn on the Thermometer sensor of my Garmin Fenix 6 device or from where can I activate this feature? Can I add this feature to widgets?
Have a nice day
The temperature widget, if you have a Tempe sensor, will pull the current temperature from the sensor and also the 24h high/low temperatures, which are stored on the Tempe sensor's onboard memory (a feature…
There is a temperature widget and a weather widget. Feel free to add either or both.
Temperature widget has limited value since it is influenced by a combination of body temperature, air temperature and…
Well if you take the watch off so that it is not influenced by body heat you could use it as a thermometer, once temperature has stabilised to ambient environment. The temperature widget will track changes…
Yes, the Tempe only sends information every minute or so.
This constant claim that it is useless.. I don’t get it why you keep doing this. If you understand how it works you can get valuable information from it.
Because it IS useless.
What kind of valuable info do you get from a sensor that measures 3 or 4 different things in proportions you don't know?
