Not Quickfit Stainless Steel Band issue
Hello Guys,
I was a big stupid. I attached a non-Quickfit steel watchband to my Fenix 6 pro watch. I was using this band for fenix 5 before. I was removing it with the help of screws. Unfortunately fenix6 pro has no screws. I noticed this after wearing the band. Now I need to pull the spring to take it out. But there is no gap. Is there anyone have an idea?
Top Replies
All Replies
  • It can work. But I think rather not. As you can see in the photo from the thread I linked, the heel of the spring bar does not overlap the outside of the bracelet. You may be able to get a razor blade into the gap between the bracelet and the hinge. But what good is that if you have no way to then push the pin aside?
    It might work if you could manage to apply enough pressure directly perpendicular to the spring bar to build up enough friction to move the pin without having to use the heel as a contact surface. But I think there is simply too little space.
  • That’s a good illustration of the problem. The gap is really small to work in. Possibly too small. I’ve used the razor blade approach in similar cases, but perhaps not as tight as this.
    But the OP has little to loose trying, I think.
