I just got the latest update but cannot find the new Ultra Run activity. Any hint how to install?
Press upper right button. Scroll up one to add. Scroll down and you'll see ultra run as an option to add. Juat press it to add. It will then always show up in your activities list.
Try looking in the list of activities below your last one - Press top right, scroll down. You’ll go through your favorites to activities added but not favourites. If not there you’ll get to the ‘+’ again…
may be, but would still like to give it a try.
Thank you all for the support. But even having the latest update, no Ultra Run is visible. Neither in the app. This is really confusing as I never had this problem before with other new sports.
Can you just double check on the watch in SYSTEM - ABOUT 1t's 15.2
Try restarting your watch?
Strange, I am only on 13.10.
This morning I did a WiFi Update and was informed that a new version is available and I pressed to install. However I did not pay attention until a moment later. I thought it was installed properly and searched for the new app. So now I have to wait until I get the updated version.
Is it an APAC (Asia-Pacific) device? Those devices usually get firmware rollouts significantly later than other devices for some reason (probably because the languages are time-consuming to properly translate), and beta firmware versions are never available for them.
If not an APAC device, you can manually install the 15.2 RC and jump the gun
