Fenix 6 Series - 14.72 Public Beta
Hello Fenix 6 customers,
Our next beta version for the Fenix 6 series is now available!
Please ensure that you are downloading the correct beta software for your specific device.
Fenix 6s: https://www8.garmin.com/support/download_details.jsp?id=15166
Fenix 6s Pro:
https://www8.garmin.com/support/download_details.jsp?id=15164
Fenix 6: https://www8.garmin.com/support/download_details.jsp?id=15162
Fenix 6 Pro:
https://www8.garmin.com/support/download_details.jsp?id=15160
Fenix 6x Pro: https://www8.garmin.com/support/download_details.jsp?id=15168
Instructions for installation are available below the change log on each of the above pages.
14.72 Change Log Notes:
  • Fixed an issue where the device was not recovering as expected after being off-course during navigation.
  • Fixed an issue where the device may display a blank segment page intermittently.
  • Fixed an issue where the HRM pro update message flow was displaying the incorrect status message.
  • Fixed an issue where the heart rate graph may intermittently display a flat line during an activity.
  • Fixed an issue where average speed during a Surf activity may be higher than the max speed intermittently.
  • Fixed an issue with bluetooth headset connectivity during activity.
  • Fixed an issue where Garmin “Power Meter” would be incorrectly labeled.
  • Fixed an issue where sleep times may not match times reported in Garmin Connect.
  • Made improvements for post activity sensor firmware updates.
  • Made improvements for Explore navigation support.
  • Regatta timer hotkey now redirects to Sail Race activity (MARQ Captian and Quatix 6 only).
  • Fixed an issue where ‘Do Not Disturb’ prevents gesture backlight from working during the sleep window.
    • Edit, 01/19/21: To clarify, We made this change because the Backlight "During Sleep" setting can now be controlled in a new area. Rather than "Do Not Disturb" automatically disabling the backlight gesture for you, you can manually select what backlight behavior you want to see during your sleep window. Please see the setting options via Menu - System - Backlight - During Sleep. The default for this setting is off, but you can change this if you would like to see the Gesture setting work during your sleep window.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 5.00
Sensor Hub: 8.00
ANT/BLE/BT (Pro models): 6.11
ANT/BLE (non-Pro models): 2.11
Wi-Fi (Pro models only): 2.60
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the Fenix 6 Series you have in the subject line.
