Software 13.10 in Garmin Express
  • Is there anything new with this update or only bug fixes?
    0 Former Member over 4 years ago in reply to Adamoo12
    • Added support for Explore Navigation Sync, where one can select lines, waypoints or generic points on the map within the Explore app and start navigating on device.
    • Added support for sport specific power zones. One can now setup their power zones for XC Ski separately from that of Cycling. (Menu > User Profile > Power Zones)
    • Added support for displaying metrics from an indoor rowing machine that supports the ANT FE-C profile (e.g. Concept 2 with the PM5 module). This includes new fields for the Indoor Rowing app: Distance, Pace, Power, and Stroke Distance.
    • Added support for an updated software update flow for ANT sensors, where the user will be prompted once they have completed the activity.
    • Added support for descriptive Varia error messages.
    • Fixed an issue impacting updates to features like VO2 max and Training Status.
    • Fixed an issue with Sail Race tack assist. (MARQ Captain and Quatix 6 only.)
    • Fixed an issue where the device could crash when connected to a HRM Pro with an active Livetrack session and accessing Ski activity profiles.
    • Fixed an issue where certain CIQ elements could not be uninstalled via Express.
    • Fixed an issue where the applied ballistics app could not be launched through the controls menu while running another app. (tactix Delta AB only).
    • Fixed an issue where the device may fail to load a considerably long activity through the history menu.
    • Fixed an issue with setting up elevation alerts at higher elevations.
    • Fixed an issue in the paring flow where the device could return to the "Pair with Phone?" page instead of moving forward.
    • Fixed an issue where customers with high resting heart rate would intermittently not accrue intensity minutes.
    • Fixed an issue where the device was not recording position data when racing against a downloaded course.
    • Fixed an issue where Daily Suggested Workouts were still present on the calendar after disabling DSW prompts.
    • Improved the reliability of ephemeris downloads.
    • Improved the presentation of information for alarms and timers.
    • Improved the scaling of lines when zooming in/out on the map.
    • Made several improvements for Sleep.
    • Made several improvements for Indoor Climb.
    • Made several improvements for daily suggested workouts.
    • Made several improvements for Livetrack.
    • Updated the Applied Ballistics bullet database to version 1215 (tactix Delta AB only).
  • But I did NOT get GPS 5.00 :(
    Why you want 5.00 if Garmin decided to officially release 4.80?
  • i think it was 12.77 then 13.00 beta brought bug fixes and 13.10 is official the same as 13.00 beta
