12.20 + 12.10 battery consumption ~20%/hr during activity
F6X Pro - I'm having problems with severe battery consumption during an activity. Wearing it around normally, battery consumption is reasonable, but as soon as I start an activity the watch burns 15-20% PER HOUR, which continues even after the activity is stopped/saved.
  • no pulseox (well, only during sleep)
  • HR strap and foot pod are connected
  • WHR is off
  • no backlight
  • no bluetooth headphones connected / no music
  • searching for tempe sensor (halfway through the activity I turned it off so it would stop searching, in case that was the problem)
  • cold air, but watch internal temp sensor is reporting 70-80 F (21-26 C) under my sleeve, so battery should be warm
This issue has been happening since 12.10 RC and now continues in 12.20. I have restarted the watch several times. I deleted the GarminDevice.xml. I sent [email protected] an email (no response), and I posted in the 12.10 RC thread. Something is really wrong -- the device should be capable of recording ~60 hours and I'm getting more like 5-6 out of a full charge. Standard everyday usage is no problem most of the time, but if I start and end an activity it starts burning power like crazy. This is a really bad bug!
I'm pretty opposed to doing a reset and losing my settings for something that might not even help.
  • Is there a Battery Widget which is recommended and has a nice design that fits fenix 6 original widgets? I've already read that some of them even cause more drain when installed.
  • I have no idea. I just use my watch. I think I’d soon be aware of any abnormal battery usage.
  • In my case, a soft reset after upgrading to 12.20 seems a have cured the problem: no more battery drain after activity (2 times already).
  • Doesn't seem far-fetched to identify a SW/FW  problem if something like this keeps popping up for different users with different updates. There is often someone commenting about an update causing excessive battery drain, even if it's not the majority of users. It sounds to me like a bug that occurs with some new software versions or is triggered at some point during the update process. I shouldn't have to periodically wipe my settings for updates to work normally. If all the betas through 11.75 worked perfectly and 12.10 suddenly shows severe battery drain, it's certainly not a hardware issue.
    I've soft reset the watch like 5x. Overnight only 4% loss with puseox, but I haven't tried another activity yet.
  • I shouldn't have to periodically wipe my settings for updates to work normally.
    You shouldn't. I don't.
    But explain to me why a problem with a few individuals reporting battery issues whenever a new version is released is a firmware problem because by that very definition it should affect all.
    It's more likely something that the individuals concerned do or have done that is peculiar to their watch than a systemic problem.
  • what a load of rubbish.
    It is a firmware issue because as in my case if I step back to a previous working firmware version, the problem goes away without any other changes to the watch. As a software developer of many years I would class Garmin firmware upgrades to be very fragile. As in there are always many seemingly random different things that go wrong on each upgrade and issues seem to be repeated or reappear in different guises. The software, if considered as a complete system seems to break very easily.
  • got 12.20 yesterday. loaded to 100%. run for about 3.5 hours including turn by turn navigation. 90% left, so no problem for me
    Hi Multiades,
    I faced same issues like you, today during a trekking I was losing 15% battery , and I tried to disable even stupid things , GLONASS or Pulse ( not OX which I don't use)
    As you says afrer finish the workout, the watch does not stop to eat battery, kills the baterry at same level. The only way to avoid watch to eat the battery is HARD Reset and then don't open again a new activity like walk or trekking because if I opne a new activity then battery starts to go down as never even if I stop the  workout.
    Pathetic ... No comments ...
    I have same option like you, and I did 5 hard resets ... Nothing solved nothing of nothing.
    Maybe someone of Garmin should improve the QA. This is not first time I face this with Fenix 6. Each time we do upgrade we need to cross fingers.
    I think is related to first wathces they delivered into market, HW revision , the new ones maybe dont face it, because they release with different chips.
    BR
  • You shouldn't. I don't.
    "I don't" seems to come with the subtext "and therefore you're doing something wrong".
    Who knows why some devices are affected and others aren't. I read about people experiencing power drain with previous updates LONG before experiencing it myself. These are relatively homogeneous devices from a hardware standpoint, even if there are minor revisions. It's not like some user-configurable thing is responsible for the problem. Maybe updating beta 11.75 -> 12.10 instead of 11.77 -> 12.10 is at fault. Who knows! But I wouldn't put the mistake on the user - this is something that needs to be explicitly spelled out or taken care of behind the scenes by the developers. Plain and simple, it's a bug. And when I send [email protected] an email, I expect to be contacted for log files or receive acknowledgement that it's being investigated. Two emails, no response. It's definitely a problem and others have experienced it.
