Anyone else experiencing issues like these? (Calorie calculations; Heart Rate)
Hi! On the latest non-beta software on a 6X non-solar. Here are the issues I've been experiencing basically since launch:
- Calorie calculations. I've noticed that, say, I'll go on a run and it says that I burned 800 calories. However, when I check my "active calories" field it will be less than that (around 700 or so, roughly). This happens 100% of the time. Is this a bug or is it, in fact, adding some of those 800 calories to my non-active calories field? I.e., it is saying I burned 800 but since it was, say a 2-hour run, some of that 800 was part of my BMR?
- Calorie calculations #2. This one I'm fairly certain is a bug. I do a lot of walking and do not start an activity for my walks because I simply don't care enough about the data from them. However, I've noticed that it gives me way too many burned calories (even active calories) considering how high my heart rate is (usually around 80-100 or so, walking briskly). It actually gives me more active calories burned on these walks than it does on my runs, it appears, or at least close to it. This is somewhat odd because when I take a yoga class, and also don't start an activity, the calories burned seem about right or maybe even a bit low. I know the moral of the story is to start and stop an activity every single time I do anything in order to get a more accurate calories reading, but it's still a noteworthy issue.
- Heart rate. I recently purchased a Polar H10 strap which basically confirmed my suspicions regarding how horrible the OHR is on the 6X. The 6X would give me horribly inaccurate readings during runs (sometimes it would report my heart rate going up on downhills and down on uphills, things like that). Part of this is that it's cold outside, and I realize OHR has inherent limitations, but IMO the 6X is essentially useless for heart rate during runs unless I'm super bundled-up; and even then the strap appears to be much more accurate. And don't even get me started on hill repeats and strength training (where the OHR is essentially worthless).
- Heart rate #2. I've also noticed that during walks and yoga classes, i.e., times where I'm active but not on an activity, heart rate will sometimes be way too low. I can usually fix this by restarting the watch, but it's an annoying issue more than anything else.
Anyone else having issues like these/have any insight on the calories things in particular?
Top Replies
All Replies
