Does it work with Pulse Ox enabled ? Or some other setting ? Thank you for any help
What I did was adding the respiration widget in the watch, I have a 6 Pro.
From version 4.10 it seems to be enabled by default. You need to add the widget to monitor it.
If you want respiration data for activities though you will have to wear a heart rate strap.
I was having an issue with this too. I added the widget on my 6X Sapphire and it showed no data and if I opened the widget it would try to measure for 30 seconds and then say "Check Watch Fit". What I did to get it working, at least for now, was to scroll down in the widget and start a breathwork exercise. I didn't finish it, only ran it for about a minute or so, and I discarded the activity but after that respiration tracking was working in the widget. I only did this today so I have to give it some time to see if it stays on. Looks like there might be a bit of a bug there but hopefully this will work as a workaround for the time being.
Yes, same for me. Initially after adding the widget I still had no readings in Garmin Connect which prompted me to ask the question. It was only when I started a breathing exercise that it started recording. The recording has now been continuous during the last 24 hours for me
Mine started recording immediately after the software update without any intervention (adding the widget or doing the breathwork). It's been visible in GCM ever since.
I can measure it by watch widget, but can't see it anywhere on GCM. Where can it be found? ( all day data )
I see under 'My Day'
I do not. :( Can somebody please post screenshot how the screen in GCM look like? Thanks.
You have to "Edit" your "My Day" screen to add it. Scroll to bottom and "Edit my day".
