We are currently phasing out SW 4.10 and sensor hub 2.50 for the Fenix 6 series of devices. This is at 20% right now.
Didn't see this one until now, 11 hours later
Anyone that got the update? Comments?
Updated mine. However, the volume control won't work on my Airpods now.
The 4.10 update installed. Some music improvements? Now, I am not able to change the volume with my bt headphones. The graphics of the volume bar is stuck, still the same position...
I would like to put…
Change Log
If you‘re on the FW 4.10, it should dissappear after about 15 seconds of keep still. When turming wrist, it comes alive again.
If you're on FW 4.10, your music, iphone and airpods should disappear as well
Again nothing for APAC versions, at least my Fenix 6X pro is still at 2.40, also beta sensor updates does not work with APAC versions.
Seriously Garmin why is APAC always last and so much behind? Is the hardware or firmware that different?
Brand spanking new to the forums. I never paid this much attention to updates with my 5x+ it worked out of the box. The broken sensor hub issues brought me here...
Does anyone knows if the Heart Rate accuracy issue solved?
Where do I find all change logs for the Garmin Fenix 6X Sapphire
Just look at the top of the forum.
Same here, first when I connect to bt. headset, earphones will start to play very loud, than when I try to set the volume, volume just goes very low and I cannot set it anymore. (I tried it to remove and add it again, happens all the time)
I would like to put the question here. I run 250m athletic lap, but fenix 6x shows me up to 50m more every single lap. Is that normal? Any tip for the settings, how to get the better precision.
Normally I use gps+glonass. Never use some 3D settings, or etc. Could it be fixed? Thanks for your comments.
Installed SW 4.10/sensor hub 2.50 2 hours ago, did a 30min run afterwards,but heart rate without is still crappy as hell. Instead of heart rate around 160bpm my 6x pro showed between 90 and 125 bpm. .
Guess I will return it, because that's a no go and I doubt they will ever get this right
Did you used a chest-strap ?
