Download HR crashes
My watch crashed during my recent run. When it restarted, I finished and saved the activity. When I try to “Download HR Data” from my HRM-Pro+, the watch says “Downloading HR Data” and then crashes/restarts again. Any way around this? Thank you.
  • Having to download HR manually, means there is something wrong. I use a HRM practically daily since many years, and in all that time I never ever had to download the HR manually. In your place I'd check first why your HRM does not connect to the watch. If it does, there is no need to download the HR manually.
    Please note, that I am not telling the bug should not be fixed (though that's not something we can help you with), but first of all you do not ever need to hit it, if your setup is correct.
  • Thanks, I also realized that something was wrong. Sweat smile  And yes, it also worked for me well for a long time, just not yesterday. I replaced the battery in the strap ( though there was no indication earlier that the battery would be low) and was hoping to be able to recover my HR data. It seems this won’t be possible.
  • Having the same issue with HRM-Pro+ and Epix Pro gen 2 watch - first it didn’t connect to HRM at all after the excercise, I changed the battery on the HRM and restarted the watch, now I try to download the data and the watch restarts every time it displays ”downloading HR data”. I’m starting to get frustrated.
