Hello everyone!
Anyone having problems with GPS monitoring on Epix pro gen 2?
I have the sapphire edition 51mm and to try to explain as precisely as possible from what I observed, in my route when I approach a road, the GPS predicts and connects to that road or if I turn from a road the GPS stays on that road and then creates some strange routes until it returns to my correct position, it makes some strange spikes or actually shows on map that I was on a different road. I have the gps settings on All + Multi-Band, the accuracy should be the highest. I understood that the deviations are up to 3 meters in this setting but in my case they are way over. I made several changes in the settings, I also reset to the factory settings. In the settings I activated Auto Pause when Stopped, I also activated 3D speed and 3D Distance. I started having these problems since the update to software 17.16. I don't know what other settings to make.
Can anyone help me with some advice?
Thank you!
