I have the Tactix 7 AMOLED and was looking to disable sleep mode with a toggle. I see there's a schedule you set for the 7 day week. I was hoping that I didn't have to say Sleep at 12:00 AM and wake at 12:01 AM. Is there another way around this?
I don't believe there is a way to totally disable sleep mode. Setting the schedule as you mentioned 12am to 12:01 might be the best workaround. You can also toggle sleep mode using the controls menu (holding down the light button), then select the moon icon. This will turn off sleep mode appearance if it's on or turn on sleep mode appearance if it is off. But it doesn't disable this feature completely. It only impacts the watch's behavior when entering sleep mode.
I recommend suggesting it to Garmin at Share Ideas | Garmin
Further issue with this. If you put your watch on DnD manually when you go to sleep, it then disables the DnD when your 1 min sleep mode ends! Meaning you'll get notifications etc after 12.01am :(
Garmin really need to add a feature to completely disable sleep mode on the Fenix 7's.
