I was unable to add my Chase credit card to Garmin pay before (it worked with debit card no problem). The new SW 17.28 fixed the problem I was able to add it first try.
Edit: just checkd wifi and it is also working now
Can you use chase on a UK watch for garmin pay? Thanks
I don't think it matters where the watch is but I'm not an expert.
no problems for me with 17.28 on the Enduro 2 with Pay!
laggy behavior is added with 17.28 in some situations, hope Garmin works on it...
go onto the garmin pay website and you can check what is supported in your region:
https://www.garmin.com/en-GB/garminpay/banks/
Chase is currently not an option. You could always ask them to add - if enough people ask chase they may just set it up with garmin.
I personally use Curve and find it works really well - haven't had an issue. It took around 30mins to get it all set up which included applying for the digital card - you just link a current card to the curve digital card and then it just passes through the cost. all my normal points etc still apply.
