Down button mapping
Down button was showing notifications yesterday, today it shows the glances. How can I reset it?
Top Replies
All Replies
  • Diff. between short press and long press?
  • Yes, I have used the hot keys feature in the app to use the down button as a shortcut to clocks.
  • Down button was showing notifications yesterday, today it shows the glances.
    Notifications is one of the glances, so it sounds like your notification glance used to be at the top of the glance list, but it was either reordered or removed. (This can happen if you use Garmin Express on a PC/Mac to manage your watch.)
    From the watchface:
    - Press UP to show the last glance in the list (above the watchface), then DOWN to show the Edit / pencil icon, then press START.
    - If Notifications is still in the glance list, scroll to it, press START to select it, then press UP/DOWN to reorder it until it’s in the position you want (first in the list), then press START again
    - If Notifications is not in the glance list anymore, scroll to the very bottom of the list to the Add / + icon, and press START. Select Notifications and press START to add it. Return to the glance list edit mode by pressing BACK, and reorder the Notifications glance as in the previous step
  • Thank you. I checked the edit, and notifications was there but listed as remove not add. As it was not in the glance list already I restarted the watch and then checked again. it was not in the glance list but was in the edit to be added. I have now added it back successfully.
    thanks again.
