Nordick Track Bike
Greetings all, i have a Nordick Track Bike that i am trying to sync with my g Epix. Has anyone found a good way of doing this?
Top Replies
All Replies
  • Hello
    While most exercise bikes have Bluetooth and ANT+, pairing with this is, in general, not successful or inconsistent. You can try this by placing the bike in pairing mode (found in your indoor bike user manual).  Then searching for this on the watch. Menu, Sensors and Access, Add new, if found select to pair with the bike.
    As an alternative to pairing with the bike, you would want to place the watch in heart rate broadcast mode. Then search for the sensor with the indoor bike (found in you indoor bike user manual). This allows your HR to appear on the bike panel with the other metrics. You would then record the activity on the watch itself.
    Then once you save the activity, and this is synced to the Connect account, you can manually edit the activity with the speed and distance data from the indoor bike panel.
