Heart rate alerts not working
Hi,
On my Epix 2 (16.22), during running activity, I can't get HR alerts working if I only set a High alert. I set the High limit to 130 and the Low limit to off, because I only wanted to keep below 130 with no lower limit. During the run my HR went above and below 130 many times without any alert. I did another run with a time alert, to confirm the alert feature in itself was working, and it worked like it should, but still no HR alerts. Then I did another test, setting low to 50 and high to 60 and walked around my apartment. Now the alerts came every time I went below 50 or above 60.
Is this a bug? Or do I have to set both high and low limits for the HR alerts to work? If so, why is there an option to set high or low limit to Off??
Either it ahould work just setting one limit to stay above or below, or the Off option should bre removed if setting both limits is necessary.
Hope someone can shed some light on this.
With Regards,
Audun
