Speedpro doesn't seem to work on windsurf mode for Epix Gen2. Is this a work in progress that will be fixed with a future software update?
I would raise a support request on it, cause it should be working - so if it is no longer working they may have borken it. But before you raise the request check the activity profile isn't corrupted if this is an actiivty you had on 16.xx software version, as 17.xx seems to have broken/corrupted quite a few activity features.
So if it is a activity you have always had on your activity list - on the watch: menu - apps & activities, select the windsurf activity, select windsurf settings - bottom option should be restore default (if you have custom screen layout and data fields then make a note so your can set it up again as restore default will clear all of this). Once restored to default you can go in and change data sreen layouts etc. WHen you select the activity from the start button - are you now getting a gps status bar at the top of the screen (usually a sign the profile is corrupted - and is speedpro now working).
it is working for me, but something is off with the speeds it is registering.
Activating speedpro in my windsurfing mode added 1 last page, when sailing this page shows you the average for the 5 best 10s runs, and the bellow the avg it list those 5 best runs with their corresponding best 10s speed.
The problem is the speeds are way off, they are slower than what other apps or GPS show for 5x10s avg. Also the individual runs show a lower speed as what other gps are showing for the same run (using a locosys BGT31 on the arm to compare). Something is not working in the way they are picking the best 10s for each run or something else.
The feature looks promising but not useful at all if its giving wrong speeds.
Bonjour, j'ai également une epix gen 2 et rien est affiché sur le mode speed pro, cela semble également ne pas marcher, j'ai pour tant remis les paramètres par default mais aucune difference. Si vous avez des solutions dites moi.
Merci d'avance
